The problem with so-called "wireless" speakers has always been their wires. Sure, a wireless surround sound speaker does not need to be plugged into your receiver or television directly, but it does need to be plugged into a power source, which means there is usually going to be a visible wire leading from a power outlet to each speaker.
Mitek has found a way to turn this lemon into lemonade by taking two devices that need power, namely a speaker and a lamp, and combining them into one. After all, every room needs lighting, right?
Honored with one of this year's CES Innovations awards, and justifiably so, Mitek's "Soundolier" cleverly combines a wireless speaker with a nicely designed torchiere-style lamp. Controls for both the lighting and the speaker are included on each lamp.
The full Soundolier system is comprised of an RF transmitter/control unit ($79.99) lamp/speaker modules ($279.99 each), and wireless powered subwoofer module($279.99). The system is expected to ship in Q2 of this year.
For those interested in the specs, the RF/control unit converts an analog signal to digital audio at 16 bits/44 KHz (the same specs as CD), then transmits a stereo digital signal at 2.4 GHz, on up to 4 independent channels, for multi-room use. The speaker's omnidirectional design broadcasts sound in all directions with a maximum SPL of 90 dB.
At CES, I spoke with the designer Spencer Dodge, while he demonstrated the Soundoliers with a variety of different movie and musical content. It was tough to get a real sense of the sound quality of the unit in such a noisy place, with about 1,000 other RF devices and networks interfering with the transmission. But the system definitely holds promise and we hope to get a set of these in for a full review on the site later this year.
