showed off its 2009 TV line this week, and things sure look (and sound) pretty.
First up is the new Unisen. What makes this TV line so special, aside from its super-slim package is that each unit in the three new Unisen series will pack a 16-speaker Dolby Digital 5.1 channel surround system.
Does that math seem right? Actually yes. Mitsubishi says that each of those speakers boasts perfectly balanced audio waves to produce a more immersive surround experience. Unlike most "virtual surround" technologies, Mitsubishi's Unisen Immersive Sound technology uses precise time delays and beaming to bounce surround channel information off your side walls so sound really comes from behind you without the need for rear speakers. You'll still need your Blu-ray player, but this design means you should be able to cut down on some of the clutter of bulky speaker cabinets and wires.
Another nifty feature is that any user can enter room dimensions to get the best possible sound for that space. You can even adjust direction, location, and sound levels for each of the five surround channels. Also, the output level for the subwoofer is controllable via remote.
Other highlights include frames measuring less than an inch, Smooth 120Hz Film Motion and Enhanced Color technologies, and the EnergyStar seal of approval. Here's a breakdown of the models and prices:
Unisen 249 Diamond Series- 46 in. – $2,799
- 52 in – $3,299
Unisen 153 Series
- 40 in. – $1,999
- 46 in – $2,399
- 52in. – $2,899
Unisen 151 Series
- 40 in. – $1,799
- 46 in – $2,199
- 52in. – $2,599
In case in-your-face sound isn’t enough, Mitsubishi also has a slew of new big screens, which include 3D-Ready technology.
The 737 Series will have that tech built into 60-, 65- , 75- and even a whopping 82-inch screen sizes. Each one includes Smooth 120Hz technology, New Advanced Video Calibration Mode, JADE Activity Based User Interface, Improved DeepField Imager, SharpEdge, Video Noise Reduction, UltraThin Frame and Mitsubishi’s Exclusive 6-Color Processor. All are also EnergyStar 3.0 rated.
The new models and prices are:
737 Series
- WD-60737 – $1,499
- WD-65737 – $1,799
- WD-73737 – $2,499
- WD-82737 – $4,199
Also boasting 3D-Ready capabilities, the 837 series has sizes from 65 to 82 inches as well. Other features include PerfectTint, four HDMI 1.3a connections, Dark Detailer and NetCommand features, a USB media input, ISFccc certification, and an RS-232C interface. The models include:
837 Series
- WD-65837 – $2,199
- WD-737837 – $2,999
- WD-82837 – $4,999
The 737 and 837 models are available now. Expect the Unisen models to ship in May.
