TigerDirect has the Vizio P50HDM plasma flat panel HDTV for a low $1199.99. This is a B-stock (refurbished) model but comes with a 90-day manufacturer's warranty on parts and labor. This deal will not last so grab one while you can!
Vizio 50-inch HD-Ready Plasma Flat Panel TV – Refurbished – $1199.99 – 7 days only or while supplies last!
Specifications from the Manufacturer:
“¢ Display Area: 50"
“¢ Aspect Ratio: 16:9
“¢ Contrast Ratio: 10000:1
“¢ Pixel Pitch: 0.81 x 0.81 mm
“¢ Resolution: 1366 x 768
“¢ Speakers: 2
“¢ Inputs: Component Video (x2), HDMI (x2), VGA, RS-232, S-Video (x2), Composite Video (x2)
“¢ Power Consumption 550W
“¢ Colors: 231 billion colors
“¢ Signal Compatibility: 480i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
“¢ Viewing Angle: >170° (horizontal and vertical)
“¢ Voltage Range: 100 ~ 240Vac at 50/60 Hz
“¢ Lamp Life: 60,000 hours
“¢ Unit Dimensions (WxHxD) 48.6" x 33.25" x 4"
“¢ Unit Weight 122 lbs.
- 50″ Diagonal with a wide-screen 16:9 Aspect Ratio enabling full-screen viewing of high-definition broadcasts and DVD videos.
- Crystal clear native resolution of 1366 x 768 pixels for optimal HDTV performance producing sharper imagery.
- High Brightness Display (1000 cd/m2) to provide a more vivid, brilliant picture in any environment.
- Superb Contrast Ratio (10,000:1) providing an incredible picture with deep blacks and bright whites in any environment.
- HDMI interface with HDCP support allows the transmission of uncompressed, copy-protected digital content to your monitor with stunning image fidelity and clarity.
- 231 billions colors for outstanding picture quality
- PiP and POP for ultimate video enjoyment while watching content from multiple video sources simultaneously.
- DCDi by Faroudja Low Angle De-interlacing Processing for superior video quality.
- Table stand and remote control included.
