It might not fit under the tree, but no recipient will mind upon receiving the Samsung LN55C630 1080p LCD HDTV set on Christmas morning. TigerDirect is offering $600 instant savings on this set to bring it to you for $1299.99. The coupon code RKZ13090 gets you the additional $100 off the listed price of $1399.99, good until December 4, or while supplies last. The TV ships free, and will go normally out the same day the order is placed.
Here is the link:
- Samsung LN55C630 LCD HDTV set– use coupon code RKZ13090
Samsung LCD speaks to the “Bigger is better” philosophy with the LN55C630 55-inch LCD HDTV. The set supports 1080p with a 16:9 aspect ratio and 120 Hz refresh rate. With four HDMI ports, USB, PC, composite and component video just about every home theater component, gaming system and device will be able to connect. The LN55C630 has built in BD Wise, which automatically adjusts all components to get the best picture and sound quality. It also adjusts to the special needs of gaming systems with the touch of a button with its Game Mode feature; this enhances dark areas, sharpens the picture and speeds up image processing response. The Game Mode also enhances the sounds in the game.
The size and features pack quite a punch for the Samsung LN55C630 LCD HDTV set. Deal is limited to stock on hand and will expire on December 4th if it lasts that long.
More Deals:
