Toshiba's
REGZAseries of LCD flat panel TVs are garnering strong reviews across the InterWeb and even in some (gasp!) print publications! And now's your chance to pick up one of these brand name beauties for the cost of the no-name dreck.
For four days only (or while supplies last), Toshiba-authorized dealer OneCall is selling its remaining stock of the 42-inch 1080p flat panel model, the 42HL167 for just $1199.97 including shipping (after application of the "HOLIDAY07" coupon code at check-out (offer ends 12/14):
Toshiba 42HL167 on OneCall: $1199.97 – 4 Days Only!Ths represents a full $500 discount off the HDTV's list price of $1699.99.
The set features 3 independent HDMI inputs and built-in "CE-Link" support which allows HDMI-enabled source and display devices to interoperate more easily and efficiently. The panel's native resolution of 1920×1080 pixels is perfectly suited to display the 1080p (60 Hz or 24 Hz) outputs of Toshiba's own HD-DVD players, Blu-ray Disc players and high-quality upconverting DVD players, as well as 1080i and 720p high definition broadcasts from satellite, cable or over-the-air signals.
The set's integrated ATSC, NTSC and QAM (digital cable) tuners make is simple to tune in your content in high definition quality, regardless of how you choose to receive your HD. And the unit's built-in 20-Watt SoundStrip speakers with SRS Wow, Dolby Digital and Stable Sound support mean that the sound quality will match the picture.
Why settle for a no-name brand this year when you can get a 1080p REGZA flat panel for less?
General Features and Specifications:- 1080p Full HD Display
- ColorBurst??? Wide Color Gamut LCD
- PixelPure 3G???14-Bit Internal Digital Video Processing
- DynaLight??? Dynamic Back Light Control
- Cinespeed??? LCD Panel
- ATSC/NTSC & QAM Digital Television Tuners
- Display Resolution 1080p (1920 x 1080)
- Colormaster???
- Native Mode???
- TheaterWide???? Modes 6 (inc. Native Mode)
- Auto Aspect Detection
- Dynamic Contrast (4-Mode)
- Static Gamma
- Color Temperature Control
- Blue & Green Drive Adjustment
- DNR for all inputs (except PC)
- 4:3 HD Mode
- Picture Freeze
- Document Mode
- SoundStrip Speaker System???
- SRS???? WOW???
- Dolby???? Digital Sound (AC-3)
- Dolby???? Digital Dynamic Range Control
- StableSound????
- Total Audio Wattage: 20 W
- Two-level Mute (Half Mute/Full Mute)
- Gloss Black Cabinetry
- 4-Item Universal Remote
- Channel Browser???
- Favorite Browser???
- Sleep Timer
- Game Mode
- Channel Labeling
- Input Labeling
- Auto No Signal Off Feature
- Auto Input Selection
- Auto Date/Time
- Built-In Discrete IR Codes
- SurfLock???
- Power-On Mode
- HDMI??? Inputs (3)
- HDMI Input Support 1080p 60/24Hz
- CE-LINK??? (HDMI CEC Support)
- HDMI Lip Sync Support
- HDMI Input PC Support VGA/480i/480p/720p/1080i/1080p
- 15 Pin D-Sub PC Input
- ColorStream???? HD Component Video Inputs (2)
- Rear S+AV Inputs(1)
- RF Input
- Audio Output (Fixed)
- Theaterlink???? IR Pass Through
- Optical Audio Outputs (1)
- Service Port (1)
- A/V Inputs – Side
- Weight: 75.19 lbs.
- Dimensions: 41.05″ x 27.86″ x 4.85″ (WxHxD)
- Weight With Stand: 88.42 lbs.
- Dimensions With Stand: 41.05″ x 30.02″ x 13.87″ (WxHxD)
- Dimensions With Packaging: 45.11″ x 33.10″ x 17.49″ (WxHxD)
