Panasonic's 58-inch 1080 plasma HDTV, the TH-58PZ700U is available for a limited time for the lowest price we've seen from an authorized dealer – $3874.99 including delivery. These new 1080p models are getting rave reviews for their picture detail, color reproduction and reproduction of moving images. Plus its oversized 58-inch screen gives you that "Big Picture" experience, even in larger rooms.
Note:You must place the item in your shopping cart and enter coupon code FALL07 in order to get this special price:
Panasonic TH58PZ700U – $3874.99 – Limited Time OnlyThis HDTV features a full 1920×1080 pixel (1080p) plasma dislay panel (PDP) as well as a new anti-glare screen coating that minimizes light reflections. It sports Panasonic's sleek new all-black frame, 2 HDMI connections, 2 component video inputs and a PC (VGA 15-pin) input.
Also Available: 50-inch Version – Panasonic TH-50PZ700U (1080p plasma) – Low Low PriceTH-58PZ700U – Full Specifications from the Manufacturer:
- Diagonal Screen Size: 58 inches
- Aspect Ratio: 16:9 (Widescreen)
- HDTV Compatibility: 480p/720p/1080i/1080p
- Native Resolution (Number of Pixels): 1920 x 1080
- Contrast Ratio: Up to 5000:1
- Progressive Scan
- Video Noise Reduction
- Digital Comb Filter: Motion Adaptive 3D-Y/C
- Color Purity Optimizer (3D Color Management)
- Sub-Pixel Controller
- Motion Pattern Noise Reduction
- Speakers: 4 (2 woofers: 8 ohms, 55 Hz – 350Hz, 10% THD)(2 tweeters: 8 ohms, 350Hz – 17kHz, 10% THD), 31W Output Power
- Surround Sound
- BBE® ViVA HD3D Sound
- Tuners: NTSC (Standard analog broadcasts), ATSC/QAM (SDTV and HDTV broadcasts)
- SD Card Slot
- HDMI-HDCP Interface: 2 rear
- Analog Audio Input (for HDMI): 2 rear
- Composite Video Input: 3 (2 rear, 1 front)
- S-Video Input 3 (2 rear, 1 front)
- Audio Input (for Video): 3 (2 rear, 1 front)
- PC Input: (RGB-VGA) Mini D-sub 15-pin (rear)
- Audio Input: (for PC) 1 (M3 Stereo Plug)
- Component Video Input [Y, PB(CB), PR(CR)]: 2 rear
- Audio Input (for Component Video): 2 rear
- Composite Video Output: 1 rear
- Audio Output: 1 rear
- Digital Audio Out: 1 (optical)
- EZ Syncâ„¢ HDAVI Control, via HDMI interface
- Video Picture Memory
- On-Screen Display Languages: English/Spanish/French
- V-Chip Program Lockout
- Built-In Closed Caption Decoder
- Timers – Sleep/On/Off Sleep (Off only)
- Video Input Labeling
- Power Supply: AC 120 V, 60 Hz
- Operating Temperature: 32°F – 104°F
- Pedestal Stand Included
- Dimensions (H x W x D): 36.1 x 57.3 x 5.6 inches
- Weight: 165.3 lbs
