The only thing better than a sexy big-screen flat panel plasma HDTV on the wall is an even BIGGER sexy flat panel plasma HDTV on the wall. And there aren't too many plasma HDTVs bigger than Panasonic's 58-inch
TH-58PX600Uflat panel.
As the new models are introduced, you can pick up the current models on clearance from authorized Panasonic dealers, for about half their original list price. OneCall currently has Panasonic's top of the line 58-inch plasma, the TH58PX600U for just
$2547.77 including shipping! That's more than 50% below its original list price.
Click here to view stock/avaiability and check current price.This is the high-end model with elegant black and silver styling, PIP, ATSC, NSTC, and digital QAM (cable) tuners, dual HDMI inputs and a computer (VGA) input. The native panel resolution is 1366×768 and it supports 480i, 480p, 720p and 1080i inputs. It is currently Consumer Reports' top-rated plasma panel in its size (and we think it looks pretty great too!).
Detailed Specifications: VIDEO:
- Diagonal Screen Size: 58 inches
- Aspect Ratio: 16:9 (Widescreen)
- HDTV Compatibility: 480p/720p/1080i
- Displayable Colors: Maximum of 29 Billion
- Shades of Gradation: 3,072
- Pixel Pitch (H x V): 0.90 x 0.675 mm
- Panel Type: 9th Generation Plasma Panel
- Aspect Control for TV/AV Modes: 4:3, Zoom, Full, Just, H-Fill (PC Mode: Normal, Full, Zoom)
- Native Resolution (Number of Pixels): 1366 x 768
- Contrast Ratio: Up to 10,000:1
- Progressive Scan
- Video Noise Reduction
- Digital Comb Filter: Motion Adaptive 3D-Y/C
- Color Purity Optimizer (3D Color Management)
- Sub-Pixel Controller
- Motion Pattern Noise Reduction
- Speakers 4: (2 woofers: 8 ohms, 55 Hz – 350Hz, 10% THD) (2 tweeters: 8 ohms, 350Hz – 17kHz, 10% THD) 31W Output Power
- BBE® ViVA HD3D Sound
- Tuners NTSC (Standard analog broadcasts), ATSC/QAM (SDTV and HDTV broadcasts)
- Photo Viewer (SD Slot)
- SD Card Slot (JPEG Photo Viewer)
- CableCARD Ready
- HDMI-HDCP Interface 2 rear
- Analog Audio Input (for HDMI): 2 rear
- Composite Video Input: 3 (2 rear, 1 front)
- S-Video Input: 3 (2 rear, 1 front)
- Audio Input (for Video): 3 (2 rear, 1 front)
- PC Input (RGB-VGA): Mini D-sub 15-pin (rear)
- Audio Input (for PC): 1 (M3 Stereo Plug)
- Component Video Input [Y, PB(CB), PR(CR)]: 2 rear
- Audio Input (for Component Video): 2 rear
- Composite Video Output: 1 rear
- Audio Output: 1 rear
- Digital Audio Out: 1 (optical)
- IR Out: 1
- EZ Syncâ„¢ HDAVI Control, via HDMI interface
- TV Guide® On-Screen Program Guide
- Video Picture Memory
- On-Screen Display Languages English/Spanish/French
- Picture-In-Picture Split Screen Display (2 Sources)
- V-Chip Program Lockout
- Built-In Closed Caption Decoder
- Timers – Sleep/On/Off Sleep (Off only)
- Video Input Labeling
Power Supply: AC 120 V, 60 Hz- Power Consumption: 399 W
- Operating Temperature: 32°F – 104°F
- Operating Humidity: 20% – 80% (Non condensation)
- Pedestal Stand Included
- Remote Control Included
- Dimensions (H x W x D) 36.2″ x 57.3″ x 5.7″
- Weight: 136.7 lbs
