Get a big TV in time for the big game and save big money doing it. Panasonic's
TH-50PZ700U1080p plasma HDTV is available now from authorized dealer OneCall for the lowest price we've seen –
$2199.99 including delivery. That's over $800 below list including a free stand or free mounting bracket. This offer expires on January 19th or while supplies last.
Note: You must place the item in your shopping cart in order to view the current price.
Panasonic TH-50PZ700U 1080p Plasma HDTV – $2199.99 Shipped
Although we have not yet done a full review of this HDTV, we’ve set up and calibrated one of these sets and put it through its paces with some pretty demanding test material, and it has impressed us with its deep blacks and jaw-dropping high definition detail. And we’re not the only ones who like it. Consumer Reports rated it the best television they’ve ever tested in their most recent round-up of HDTVs. And CNET rated its larger and smaller brethren an “excellent” 8.0 out of 10.
The TH-50PZ700U’s anti-reflective screen coating is effective at minimizing room reflections and its full HD 1920×1080 pixel panel is a perfect match for 1080i broadcast HDTV or 1080p movies on Blu-ray Disc. The set sports Panasonic’s sleek all-black frame, 2 HDMI connections, 2 component video inputs and a PC (VGA 15-pin) input.
You can also upgrade to the TH-50PZ750U model with an extra HDMI input, AVCHD video playback from SD cards and pro calibration features for $250 more ($2449.97) or go REALLY BIG with the 58-inch model for $3199.97. All three of these models qualify for OneCall’s free stand or free wall-mount bracket offer (a $100-$200 value). Just supply coupon code “FREESTAND” or “FREEBRACKET” at check-out (stand/bracket offer expires 1/28/07).
- Panasonic TH-50PZ750U 50-inch 1080p Plasma HDTV with Professional Calibration Settings and 3 HDMI Inputs: $2449.97
- Panasonic TH-58PZ700U 1080p 58-inch Plasma HDTV: $3199.97
All of the above models also qualify for Panasonic’s $200 mail-in rebate. If you have the set professionally installed or mounted, send a copy of your receipt in with Panasonic’s mail-in rebate form, and you will receive a check from Panasonic for up to $200 toward the installation cost (purchase must be made by 1/31/08, installation completed by 2/15/08).
TH50PZ700U – Full Specifications from the Manufacturer:
- Diagonal Screen Size: 50 inches
- Aspect Ratio: 16:9 (Widescreen)
- HDTV Compatibility: 480p/720p/1080i/1080p
- Shades of Gradation: 4,096
- Native Resolution (Number of Pixels): 1920 x 1080
- Contrast Ratio: Up to 5000:1
- Progressive Scan
- Video Noise Reduction
- Digital Comb Filter: Motion Adaptive 3D-Y/C
- Color Purity Optimizer (3D Color Management)
- Sub-Pixel Controller
- Motion Pattern Noise Reduction
- Speakers: 4 (2 woofers: 8 ohms, 55 Hz – 350Hz, 10% THD)(2 tweeters: 8 ohms, 350Hz – 17kHz, 10% THD), 31W Output Power
- Surround Sound
- BBE???? ViVA HD3D Sound
- Tuners: NTSC (Standard analog broadcasts), ATSC/QAM (SDTV and HDTV broadcasts)
- SD Card Slot
- HDMI-HDCP Interface: 2 rear
- Analog Audio Input (for HDMI): 2 rear
- Composite Video Input: 3 (2 rear, 1 front)
- S-Video Input 3 (2 rear, 1 front)
- Audio Input (for Video): 3 (2 rear, 1 front)
- PC Input: (RGB-VGA) Mini D-sub 15-pin (rear)
- Audio Input: (for PC) 1 (M3 Stereo Plug)
- Component Video Input [Y, PB(CB), PR(CR)]: 2 rear
- Audio Input (for Component Video): 2 rear
- Composite Video Output: 1 rear
- Audio Output: 1 rear
- Digital Audio Out: 1 (optical)
- EZ Sync??????? HDAVI Control, via HDMI interface
- Video Picture Memory
- On-Screen Display Languages: English/Spanish/French
- V-Chip Program Lockout
- Built-In Closed Caption Decoder
- Timers – Sleep/On/Off Sleep (Off only)
- Video Input Labeling
- Power Supply: AC 120 V, 60 Hz
- Operating Temperature: 32????F – 104????F
- Pedestal Stand Included
- Dimensions (H x W x D): 31.6 x 49.9 x 5.5 inches
- Weight: 105.8 lbs
