It’s Friday! Are you ready to rock the weekend? If your answer is, “No,” then you might want to think about a new set of speakers. Thankfully, Amazon has an easy, affordable solution in the Klipsch HD 500 5.1 Home Theater Speaker System.
This set features everything you need to start rocking out to music, movies, and even the evening news. OK… the last one may be a stretch. Maybe not, though. You will want to crank this set so everyone can hear, be amazed, and even ask how much you actually paid for it. Yes, there will be some bragging, because Amazon is currently listing the HD 500 as its Gold Box Deal. That means for one day (Friday, February 18, 2011), you will save 50 percent off this full 5.1 speaker setup, making the cost $299.99 shipped. Find out more about the deal here:
The HD 500 is a complete speaker solution. Inside the box, you’ll find four small speakers a slightly larger center channel, and a rear-ported 8-inch subwoofer. The system also comes with everything that you’d need to mount those five speakers.
Each speaker features a shiny black finish, as well as a 2.5-inch IMG woofer and a MicroTractrix Horn-loaded 0.75-inch aluminum dome tweeter. The center channel is also magnetically shielded, so it won’t interfere with your TV at all. The speaker set is nicely matched with an 8-inch 100-watt powered subwoofer. Find out more about this full set on Amazon’s product page:
This package is perfect if you’re looking to start (or replace) your audio setup — especially if you’re on a budget. If you want to get the low price and free shipping, make sure to buy directly from Amazon and not one of its third-party merchants. However, you’d better act quickly; this deal is only good for today, or until the retailer runs out of stock.
