Sony's highly rated 1080p home theater projector, the
VPL-VW100has garnered some rave reviews since its introduction last year. OneCall has just discovered three "open box" samples of the projector in their warehouse and they're blowing them out at about 35% of the retail price: just
$3677.97 including FedEx delivery:
Sony VPL-VW100 1080p SXRD projector on OneCall (Open Box)Though these boxes have been opened (store display units or customer returns), they are still covered by Sony's full 2-year parts and labor warranty, as well as OneCall's own satisfaction guarantee. Get a great deal on an excellent projector. Only three units are available at this price.
When you consider its 15,000:1 contrast ratio, full 1080p HDTV resolution (1920X1080 pixels progressive), and the fact that most 3-chip DLP and DILA projectors sell for at least twice the price or more, this is one phenomenal deal on a great projector.
Manufacturer’s Specifications: Video Features- Wide Mode (16:9): Wide Mode (Full, Normal, Wide Zoom, Zoom)
- Horizontal Size: Yes
- Vertical Position: Yes
- DRC® Mode: Mode 1, Mode 2, Off
- Panel Type: 0.61 inch SXRD™ panel (2,073,600 pixels per panel. 6,220,800 total pixels)
- Dot Phase: Yes
- Picture Shift Function: Yes
- Title Area Control: Yes
- Film Mode: Yes
- Screen Area: Yes
- DRC® Palette Presets: Mode 1, Mode 2
- Acceptable Video Signals: 15 kHz (RGB/Component) 50/60Hz, Progressive component 50/60 Hz, DTV (480/60i, 575/50i, 480/60p, 575/50p, 720/60p, 720/50p, 1080/60i, 1080/50i, 1080/60p – HDMI input only, 1080/50p – HDMI input only, Composite video, Y/C video.
- Power Save Mode: (On, Off)
- Auto Input Search: Yes
- Test Pattern: Yes
- Image Flip: HV, H, V, Off
- IR Receiver: Front & Rear, Front, Rear
- Illumination: Off, On
- Multiple Language Display: 15 languages including English, French, Spanish, German and Chinese
- Display Resolution: 1920 x 1080p
- Video Signal System: Acceptable Video Signals: 15 kHz (RGB/Component) 50/60Hz, Progressive Component DTV (480/60i, 575/50i, 480/60p, 575/50p, 720/60p, 720/50p, 1080/60i, 1080/50i), 1080/60p (DVI and HDMI channel only), Composite video, Y/X video
- Color Systems: Auto, NTSC, PAL, SECAM
- 12V Trigger: 1 (1 Side) Mini Jack – Power On: DC 12V, output impedance: 4/7 kilohms Power Off: 0V
- HDMIâ„¢ Connection(s): 1 (1 Side) Digital RGB/Y/Cb(Pb)Cr(Pr)
- Component Video (Y/Pb/Pr ) Input(s): 1 (1 Side) Y/Cb/Pb/Cr/Pr
- Input(s): Input A – HD D-sub 15-pins, Analog RGB/component: R/Cr (Pr): 0.7 Vp-p+/-2 dB (75 ohms terminated), G: 0.7 Vp-p+/-2 dB (75 ohms terminated), G with synch/Y: 1 Vp-p+/-2 dB synch negative(75 ohms terminated), B/Cb (Pb): 0.7 Vp-p+/-2 dB (75 ohms terminated), SYNC/HD: Composite sync input: TTL level, positive/negative, Horizontal sync input: TTL level, positive/negative
- Composite Video Input(s): 1 (1 Side) Vp-p+/-2 dB sync negative (75 ohms terminated)
- S-Video Input(s): Y/C mini DIN 4-pin type, Y (luminance): 1 Vp-p+/-2 dB sync negative (75 ohms terminated) C (chrominance): burst 0.286 1 Vp-p+/-2 dB (NTSC) sync negative (75 ohms terminated) burst 0.3 1 Vp-p+/-2 dB (PAL) sync negative (75 ohms terminated)
- HDMI Connection Input(s): 1 (1 Side) Digital RGB/Y/Cb(Pb)Cr(Pr)
- Remote Network Connection(s): 1 (1 Side) RS-232C: D-sub 9-pin (female) RJ-45 10 BASE-T/100BASE-TX (For gamma adjustment using included ImageDirector2 software.)
- RS232 Control: Remote Connector
- DVI Connection Input(s): DVI-D (TMDS) – Digital RGB
- Power Requirements: AC 100 to 240V, 0.8 to 1.95A, 50/60Hz
- Power Consumption (in Operation): Max. 610W
- Power Consumption (in Standby): 10W
- Measurements (W x H x D): 19 1/2″ x 6 7/8″ x 22 5/8″ (496 mm x 175 mm x 574 mm)
- Weight: 41 lbs 13 oz (19 kg)
- Vertical Keystone: Yes
- Standby Mode: Yes
- Lens Control: Off, On
- High Altitude Mode: Off, On
- Information Menu: Horizontal and Vertical frequency display
- Panel Type: 0.61″ SXRD panel (2,073,600 pixels per panel. 6,220,800 total pixels)
- Input A: A Signal Setting (Auto, Computer, Component, Video GBR)
- DVI Signal Setting: Auto, Computer, Video GBR
- Operating Temperature: 0 degrees C to 35 degrees C (32 degrees F to 95 degrees F)
- Operating Humidity: 35% to 85% (no condensation)
- Lens: fl 8.7 to 33.7 mm/F2.54 to 3.53 mm
- Projection Picture Size: 40 to 300 inches (diagonally)
- Limited Warranty: 2 Year Parts, 2 Year Labor
- Remote Control (RM-PJVW100)
- Instruction Manual
- Xenon Replacement Lamp (LMP-H400)
- Black Ceiling Mount (PSS-610)
- White Ceiling Mount (PSS-H10)
