Sure, flat panel HDTVs are cool, but if you want a really BIG screen flat panel (65 inches or more), then be prepared to plop down a cool $5Gs (yes, five thousand dollars). If you’ve got some space, and a hankering for that really BIG PICTURE, then you can’t do much better than this new deal from Tiger Direct. They’re offering Samsung’s 67-inch DLP HDTV (the HL67A510) for a low $1499.99 including a free matching stand. That’s a savings of $600 off list.
Here’s the link to check out this deal:
This is a brand new (factory fresh) 1080p HDTV, with full manufacturer’s warranty. It features a respectable 10,000:1 Contrast Ratio, on-board ATSC and QAM digital tuners and three HDMI inputs for compatibility with the latest high definition sources like Blu-ray Disc, HD cable and satellite set-top boxes.
Samsung HL67A510 Specifications from the Manufacturer:
Video | ||||||||||||
Audio | ||||||||||||
Input & Output(Side) | ||||||||||||
Input & Output(Back) | ||||||||||||
System | ||||||||||||
Dimensions | ||||||||||||
Weight | ||||||||||||
