Why settle for a second tier brand HDTV when you can get a huge Pioneer plasma flat panel for less?
Second Acthas brand new 60-inch Pioneer Plasma HDTVs in stock (model number PDP6071HD) for just $2699.99 plus shipping.
Pioneer PDP6071HD 60-inch plasma HDTV for $2699.99Pioneer plasmas are known for their black level reproduction, color accuracy and almost three-dimensional detail. To get a Pioneer plasma in the 60-inch size for under $3,000 is a rare find indeed so pick one up now before they run out of stock.
Our home theater editor reviewed the 42-inch version of this set (the
PDP-4270) earlier this year and rated it "near the top of its class" and now you can get the 60-inch version for
lessthan the original list price of the 42-inch version.
The set includes support for 1080p inputs (including 1080p/24), built-in ATSC and NTSC tuners (with CableCard support), built-in TVGuide OnScreen program guide, PIP, PC support, Pioneer's proprietary deep-encased cell structure panel and advanced video processing which makes standard definition content look good and high definition content look even better.
Specifications from the Manufacturer:- Screen Size: 60 inches (diagonal)
- Aspect Ratio: 16:9 Widescreen
- Input format support: 480i, 480p, 720p, 1080i, 1080p/60, 1080p/24
- High Definition WXGA Native Panel Resolution (1365 x 768 pixels)
- Viewing Angle: 160???? (horizontal and vertical)
- New First-Surface Pure Color Filter for enhanced contrast, color and reduction in light reflection on screen
- Crystal Emissive Layer for deeper blacks and increased brightness of images
- Pure Drive II Signal Processing – Full time 10-bit Digital Video Processing delivers a low noise, high contrast, natural colored image
- ACE IV (Advanced Continuous Emission) for reproduction of billions of colors and improved grey-scale rendering in dark picture areas
- Advanced PureCinema??? with 3:2 pull down so that film-based material on DVD, videotape or even regular TV will match the smooth and natural reproduction seen in a movie theater
- Fully Integrated Media Receiver with Dual NTSC and ATSC Tuner with CableCARD??? Interface
- 2 Independent HDMI Inputs (10-bit Processing) with the Ability to Accept a 1080p/24Hz Signal and analog audio inputs
- 3 Component Video inputs
- 1 Computer Input (VGA)
- 4 Composite Video Inputs
- 2 S-Video Inputs
- Antenna A & B Input
- USB Input (Mass Storage Class) (Side Input)
- Aspect Ratio Control – 6 positions (Wide/Zoom/Cinema/Full/4:3/”Dot by Dot” for PC only)
- TV Guide On Screen???? Interactive Program Guide for easy navigation of TV program services
- A/V Selection Memory – 5 options for viewing preferences (Standard/Dynamic/Movie/Game/User)
- Split Screen/Picture in Picture display modes to view multiple sources at one time
- Home Gallery offering a convenient way to view photos via USB connection
- 13 Watt Stereo Amplifier With TruBass???? 2-Way
- Stereo Speakers with SRS???? WOW????/FOCUS&/TruBass Surround Sound Audio
- Dimensions: 57.9″ W x 34.7″ H x 4.7″ D;
- Weight: 114 lbs.
