It’s the Black Friday party that never ends! J&R has Panasonic’s excellent TH-42PX80U 720p Plasma HDTV right now for $649.99 until 12/6 (or while supplies last). That’s a savings of $550 off MSRP! Why settle for budget brands when you can get a Panasonic for less?
Here’s the Link:
This HDTV features three HDMI inputs with input resolution all the way up to 1080p for compatbility with the latest high definition source components such as Blu-ray Disc and HD set-top boxes. It also includes a built-in high definition ATSC tuner for reception of free digital over-the-air broadcasts. The screen features a new anti-reflective coating to minimize the reflection of light off the screen – perfect for viewing the TV in higher ambient light conditions.
Manufacturer’s Specs on the Panasonic TH-42PX80U
Treat yourself with the new Panasonic Viera Plasma 42″ HDTV, you’ll enjoy watching your favorite shows and sporting events on the large 42″ screen TV in high definition. The Panasonic Viera Plasma gives you intense colors, excellent contrast and the sharpest images. You can even display all your favorite photos from your digital camera with the built-in SD card slot, giving you your own virtual photo gallery inside your living room.
- 42″ Class (41.6″ diagonal)
- 720p Display Resolution
- Input formats supported: 480i, 480p, 720p, 1080i, 1080p
- 1024 x 768 Native Pixel Resolution
- 16:9 (Widescreen) Aspect Ratio
- 720 lines or more Moving Picture Resolution
- 1,000,000:1 Dynamic, 15,000:1 Native Contrast Ratio
- G11 Progressive 1080p HD Plasma Display Panel Type
- Motion Adaptive 3D-Y/C Digital Comb Filter
- Two Full-range (L,R) Speakers, 20Watt (10% THD)(8ohms, 70Hz-17kHz)
- Integrated ATSC Tuners
- ATSC / QAM / NTSC Receiving System
- SD Card Slot, Photo Viewer
- Input Ports: 3 x HDMI (1 Front), 2 x Analog Audio Input (for HDMI), 2 x Composite Video (1 Front), 2 x S-Video (1 Front), 2 x Audio Input (1 Front) (for Video), 1 x Composite Video output, 1 x Audio Output, 1 x Digital Audio Out
- Approximate Unit Dimensions: 28.6″ (H) x 40.2″ (W) x 15.2″ (D) with Stand
- Approximate Unit Weight: 61.8lbs with Stand
- MRSP: $1199.95
