Advertisement
Panasonic's TH-50PZ700U) is available this weekend for the lowest price we've seen – $2399.99 including delivery. That's over $1000 below list. Although we have not yet done a full review, we've set up and calibrated one of these puppies and put it through its paces with some pretty demanding test material, and it has wowed us with its deep blacks and impressive picture detail.
Note:You must place the item in your shopping cart in order to view the current price:
Panasonic TH50PZ700U 1080p Plasma HDTV – $2399.99This HDTV features a full 1920×1080 pixel (1080p) plasma panel as well as a new anti-glare screen coating that minimizes light reflections. It sports Panasonic's sleek new all-black frame, 2 HDMI connections, 2 component video inputs and a PC (VGA 15-pin) input.
TH50PZ700U – Full Specifications from the Manufacturer:- Diagonal Screen Size: 50 inches
- Aspect Ratio: 16:9 (Widescreen)
- HDTV Compatibility: 480p/720p/1080i/1080p
- Shades of Gradation: 4,096
- Native Resolution (Number of Pixels): 1920 x 1080
- Contrast Ratio: Up to 5000:1
- Progressive Scan
- Video Noise Reduction
- Digital Comb Filter: Motion Adaptive 3D-Y/C
- Color Purity Optimizer (3D Color Management)
- Sub-Pixel Controller
- Motion Pattern Noise Reduction
- Speakers: 4 (2 woofers: 8 ohms, 55 Hz – 350Hz, 10% THD)(2 tweeters: 8 ohms, 350Hz – 17kHz, 10% THD), 31W Output Power
- Surround Sound
- BBE® ViVA HD3D Sound
- Tuners: NTSC (Standard analog broadcasts), ATSC/QAM (SDTV and HDTV broadcasts)
- SD Card Slot
- HDMI-HDCP Interface: 2 rear
- Analog Audio Input (for HDMI): 2 rear
- Composite Video Input: 3 (2 rear, 1 front)
- S-Video Input 3 (2 rear, 1 front)
- Audio Input (for Video): 3 (2 rear, 1 front)
- PC Input: (RGB-VGA) Mini D-sub 15-pin (rear)
- Audio Input: (for PC) 1 (M3 Stereo Plug)
- Component Video Input [Y, PB(CB), PR(CR)]: 2 rear
- Audio Input (for Component Video): 2 rear
- Composite Video Output: 1 rear
- Audio Output: 1 rear
- Digital Audio Out: 1 (optical)
- EZ Syncâ„¢ HDAVI Control, via HDMI interface
- Video Picture Memory
- On-Screen Display Languages: English/Spanish/French
- V-Chip Program Lockout
- Built-In Closed Caption Decoder
- Timers – Sleep/On/Off Sleep (Off only)
- Video Input Labeling
- Power Supply: AC 120 V, 60 Hz
- Operating Temperature: 32°F – 104°F
- Pedestal Stand Included
- Dimensions (H x W x D): 31.6 x 49.9 x 5.5 inches
- Weight: 105.8 lbs
