Panasonic's new 1080p plasma HDTVs are finally available, and the prices are actually pretty reasonable, with the 50-inch model (TH-50PZ700U) priced at just $3500. That's less than half the cost of 1080p plasmas available last year. And although we have not yet done a full review, we've calibrated one and put it through its paces with some pretty demanding test material, and it has wowed us with its deep blacks and impressive picture detail.
And our affiliate partner Second Act is now offering this 50-inch 1080p flat panel plasma for just
2499.99until August 26th or while supplies last, using an exclusive coupon code at checkout for instant savings.
Note:10-2-07: Second Act is no longer carrying this TV but authorized dealer OneCall is, at an even lower price: $2399.99 including free curbside delivery. Place the item in your cart in order to view current price:
Panasonic TH-50PZ700U on OneCallThis HDTV features a full 1920×1080 pixel (1080p) panel as well as a new anti-glare screen coating that minimizes light reflections. It sports Panasonic's sleek new all-black frame, 2 HDMI connections, 2 component video inputs and a PC (VGA 15-pin) input.
TH-50PZ700U – Full Specifications from the Manufacturer:- Diagonal Screen Size: 50 inches
- Aspect Ratio: 16:9 (Widescreen)
- HDTV Compatibility: 480p/720p/1080i/1080p
- Shades of Gradation: 4,096
- Native Resolution (Number of Pixels): 1920 x 1080
- Contrast Ratio: Up to 5000:1
- Progressive Scan
- Video Noise Reduction
- Digital Comb Filter: Motion Adaptive 3D-Y/C
- Color Purity Optimizer (3D Color Management)
- Sub-Pixel Controller
- Motion Pattern Noise Reduction
- Speakers: 4 (2 woofers: 8 ohms, 55 Hz – 350Hz, 10% THD)(2 tweeters: 8 ohms, 350Hz – 17kHz, 10% THD), 31W Output Power
- Surround Sound
- BBE® ViVA HD3D Sound
- Tuners: NTSC (Standard analog broadcasts), ATSC/QAM (SDTV and HDTV broadcasts)
- SD Card Slot
- HDMI-HDCP Interface: 2 rear
- Analog Audio Input (for HDMI): 2 rear
- Composite Video Input: 3 (2 rear, 1 front)
- S-Video Input 3 (2 rear, 1 front)
- Audio Input (for Video): 3 (2 rear, 1 front)
- PC Input: (RGB-VGA) Mini D-sub 15-pin (rear)
- Audio Input: (for PC) 1 (M3 Stereo Plug)
- Component Video Input [Y, PB(CB), PR(CR)]: 2 rear
- Audio Input (for Component Video): 2 rear
- Composite Video Output: 1 rear
- Audio Output: 1 rear
- Digital Audio Out: 1 (optical)
- EZ Syncâ„¢ HDAVI Control, via HDMI interface
- Video Picture Memory
- On-Screen Display Languages: English/Spanish/French
- V-Chip Program Lockout
- Built-In Closed Caption Decoder
- Timers – Sleep/On/Off Sleep (Off only)
- Video Input Labeling
- Power Supply: AC 120 V, 60 Hz
- Operating Temperature: 32°F – 104°F
- Pedestal Stand Included
- Dimensions (H x W x D): 31.6 x 49.9 x 5.5 inches
- Weight: 105.8 lbs
