Are you ready to rock? If not, you might want to check out your speaker situation. Even with the biggest, brightest HDTV or projection system, bad audio can really throw off your entire viewing experience.
That said, building an awesome audio system does not have to be a daunting task. You don’t have to build that setup piece by piece. Most manufacturers offer some type of bundle to make your purchase an easy one. And for a limited time, Amazon is going to super-size some of those orders.
Right now, if you buy MartinLogan’s Motion 262 5-Channel Speaker Set, Amazon will throw in a matching MartinLogan Dynamo 500 Subwoofer. The sub typically sells for $495 on its own, so this is a nice little freebie. They are also sweetening the pot, by discounting the Motion 262 series by 25% and offering free shipping on both items. Check out this offer here:
MartinLogan’s Motion 262 set comes with five speakers: four Motion 2 speakers (for front left, right and surround duties) plus one Motion 6 center channel speaker. All feature a rated frequency response of 120Hz-25kHz, a piano black finish, and an elegant curved design. But the highlight of the series is MartinLogan’s Folded Motion Tweeter, which gives midrange and high frequencies a uniquely transparent sound normally only found in much more expensive speakers.
Our own Dennis Burger recently got to check out the Motion 262 system, saying, “I’m almost inclined to think they’re entirely too inexpensive.” Better not let the good people at Amazon read that! Check out his MartinLogan Motion 262 system review. He reviewed this exact system but with a slightly larger subwoofer. He liked the set so much they won our prestigious BIGGIE Award for 2010. When you’re done reading, head on over to Amazon to order yourself a set.
While you are rushing to order those speakers, don’t forget the subwoofer. It won’t just add incredible depths and low frequency power to your system, but it’s FREE with the purchase of the Motion 262 speaker set. How often do you get offered a free subwoofer? This one is a doozy, too, packing a 10-inch woofer and high-current 120-watt RMS (360-watt peak) amplifier into this compact cabinet. Read more about this subwoofer on Amazon’s product page:
You must buy both products from Amazon.com as the seller (not one of its third-party merchants) in order to get the discounted pricing and free shipping. Just remember to add both items into your shopping cart; your savings will be reflected during the checkout process. These discounts are being offered from now through February 28, 2011 or whenever Amazon runs out of stock.
