Still rocking out with that boombox? OneCall has a good little speaker deal you’ll want to scoop up — but you’d better hurry. For today only, they are offering $500 in savings on the MCS130 5.1 Speaker System from Boston Acoustics.
So in other words, you could score a full set of five speakers and a subwoofer, all for under $300. All five satellite speakers have two 3.5-inch woofers and a 1-inch tweeter to crank anywhere from 10 to 150 watts of sound. The three front units have a frequency response of 110Hz – 20kHz, while the surrounds do 120Hz – 20kHz. The 10-inch subwoofer does 200 watts, with a frequency response of 40 – 150Hz. Check out the entire setup by clicking on this link:
The speakers are also super compact and light, making them perfect to hang or place on a shelf. The fronts weigh 5 pounds, while the surrounds are about 3 pounds. At 31.25 pounds, the subwoofer has a bit more girth — and it should!
This set also includes plenty of speaker wire and a subwoofer cable, so you can rock right out of the box. It also comes with four rubber bumpers, two feet and two thumb screws, for a variety of install options.
Overall, this price means you will save 63 percent, but you’d better act quickly — the deal is done at the end of the day!
