It’s feeling like a musical Christmas. If you’re looking to build your home theater set-up, or are looking to give the gift of music to someone else, Amazon.com has a deal for you on a Klipsch and Yamaha combo. Put a Klipsch HD 500 Compact 5.1 Home Theater System and a Yamaha RX-V471BL AV Receiver in your cart, and you’ll find the total system price reduced to $599.99. Who needs a cheesy “home theater in a box” when you can get high-end specialized components for about the same price?
See the offer page on Amazon for details or to purchase the system:
The Klipsch HD 500 Compact 5.1 Home Theater system alone sells for $599.99, so it’s like getting the Yamaha RX-V471BL AV Receiver, which has a list price of $379.95 and sells on Amazon.com for $299.95, for free.
An impressive compact surround sound speaker system, the Klipsch HD 500 5.1 Home Theater System is comprised of six pieces. The set comes with a center channel, front left and right speakers and two surround speakers plus an 8-inch pwoered subwoofer. The four satellite speakers contain a 2.5-inch IMG woofer and a .75-inch Aluminum Micro-Tractrix horn-loaded tweeter while the center speaker has a pair of 2.5-inch IMG woofers and a .75-inch tweeter of the same construction. Klipsch boasts the horn-loaded Micro-Tractrix feature on its speakers produce a more lifelike sound. This horn-loaded design also offers higher SPL output with less power and energy consumption than comparable speaker systems.
The speakers are polished with a high gloss black finish and the subwoofer comes in a Black Pica finish. The subwoofer has crossover, phase and level controls for fine-tuning the bass output.
A perfect companion to the Klipsch surround sound system is the Yamaha RX-V471BL AV Receiver. Yamaha built this 1080p compatible HDMI receiver with integrated 3D passthrough and supportsa for the HDMI Audio Return Channel. It has a compressed music enhancer with CINEMA DSP for a full sound from all sources, whether it’s a Blu-ray movie, sit-com or Sunday’s game.
Plug an iPod, iPhone or other device into the receiver with the USB digital connection located in the front panel for easy access. The Yamaha RX-V471BL AV Receiver has two automatic volume settings: the turn-on volume setting and the maximum volume setting, which allows you to cap how loud the set gets, and also means you won’t blast yourself off the couch when you turn on the receiver.
Amazon.com’s offer for the Klipsch HD 500 Compact 5.1 Home Theater System and Yamaha RX-V471BL AV Receiver pair for $599.99 is good through December 31, 2011, or while supplies last. You can wait to see if it will be under the tree, but it might be out of stock if you wait that long.
More Holiday Deals on HDTV and Home Theater:
