Here’s the link (click to view details):
- Hitachi P50S601 50-inch Full HD 1080 Plasma HDTV: $1199.99 (TigerDirect – price current as of 4/30/08)
The set features three 1080p-compliant HDMI inputs, a sleek gloss black frame, 16-bit color processing and an anti-reflective screen to minimize glare. This is a fantastic deal on a great plasma flat panel television. Grab one while they last!
Note: You must add this item to your cart and check-out in order to get this deal. If you leave it in your cart expecting to check-out later, it may run out of stock before you check out.
Also, if you want to upgrade to their even higher performance P50V701 model, with its super-cool motorized swivel base, CableCard compatibility, TV Guide OnScreen and Reel60 Film mode, you can do that for just $200 more.
How good a deal is this?I just bought one.And I already have a 50-inch plasma!
Note: Tiger Direct is also a marketplace seller on Amazon.com so these links also work (for now):
- Hitachi P50S601 50-inch Plasma HDTV on Amazon.com ($1199.99)
- Hitachi P50V701 50-inch Plasma HDTV on Amazon.com ($1399.99)
Manufacturer’s Specifications ( Hitachi P50S601):
Performance Features:
- Full HD1080 High-Definition Display (1920×1080 pixels)
- ClearWindowâ„¢ Plasma Technology
- High-Aperture Pixel Design
- PictureMasterâ„¢ HD IV Video Processor
- MPEG Noise Reduction
- Dynamic Contrast
- Dynamic Histogram Processing
- 16 Bit/281 Trillion Color Capability
- Automatic 3:2 Film Enhancement
- 4 HD Aspect Modes
- 6 SD Aspect Modes
- Quick Start Seamless HDTV (ATSC) and NTSC Tuners
- QAM- Digital Cable Compatible
- Pure HDTV Blue and Red
- 3 Preset Color Temperatures
- 4-Step Black Enhancement
- 10-Bit Digital 4MB 3D Y/C Comb Filter
- Anti-Reflective Screen
- High Contrast
- Black-Stripe Filter
Convenience Features:
- 3 HDMI SimplayHDâ„¢ 1080p Compatible Inputs (1 Front)
- 2 Wideband Component Video Inputs
- Power Swivel Tabletop Stand
- Day Dynamic/Day and Night Memory by Input with Timer
- Multi-Function Remote Control
- Front Panel Menu Controls
- 3-Language On-Screen Display
- Parental Locks (Downloadable V-Chip)
- Closed Caption Decoder
- On/Sleep Timers
- Auto Link Input Sensor
- Discrete IR Codes
- Multiple Picture Orbiting Options
Audio Performance Features:
- MTS Stereo SAP with dbxâ„¢
- Simulated Surround Sound
- Bass Boost
- 20-Watt Speaker System
- Mute and Soft Mute
- TV-as-Center Speaker
- All Inputs (L/Mono)
Inputs/Outputs
- (3) HDMI SimplayHDâ„¢ 1080p Compatible Inputs (2 Rear/1 Front)
- (2) Wideband Component Video Inputs:
- (4) AV Inputs (3 Rear/1 Front)
- S-Video Input
- RF/Antenna Input
- AV Monitor Output (Fixed Audio)
- S-Video Monitor Output
- Optical Digital Audio Output
- RS232 – ControlPort
- MMC Card Slot (Service Upgrade only)
Warranty:
- 1-Year Parts and Labor Warranty (In Home Service)
Dimensions:
- Boxed Shipping Dimensions (WxHxD): 55 13/16″ x 39 3/8″ x 20 1/16″
- Boxed Weight: 134.5 pounds
- Dimensions With Stand (WxHxD):46.8″ x 34.8″ x 16.68″
- Unit Dimensions (WxHxD):46.8″ x 32.3″ x 5.06″
- Unit Weight:104.9 lbs.
Manufacturer’s Specifications ( Hitachi P50V701):
- Reel60â„¢ Film Processing
- PictureMasterâ„¢ HD V Video Processor
- Dynamic Contrast
- 4 HD Aspect Modes
- 6 SD Aspect Modes
- Game Mode
- CableCARDâ„¢ Compatible
- Split Screen Capability
- High Contrast
- Deep Black-Stripe Filter
- TV Guide On Screen® IPG
- Compatible Inputs: 2 (1 Front)
- Multi-Function Remote Control with Glow Keys
- On/Sleep Timers
- Adjustable Audio Delay
- IR Pass-through
- Discrete IR Codes
- SDâ„¢ Card Photo Viewer
- Slideshow and Rotate Functions
- Bass Boost
- Specifications
- Resolution: 1920 (H) x 1080 (V) x3
- FCC Rating: Class B for Consumer Use
- Weight with Stand: 105.4 lbs.
Inputs/Outputs:
- S-Video Input
- RF/Antenna Input
- CableCARDâ„¢ Interface
- SDâ„¢ Card Input
- IR Output Ports
Warranty:
Dimensions:
- Boxed Shipping Dimensions (WxHxD): 55 13/16″ x 39 3/8″ x 20 1/16 inches
- Dimensions With Stand:48.8″ x 34.8″ x 16.7″
- Unit Dimensions (WxHxD):48.8″ x 32.3″ x 5.06″
- Unit Weight:105.4 lbs.
